FJ55 spring bushings are a little odd in their size - 1 3/8" OD and 18mm (11/16") ID. I looked at the bushings offered by Specter and, if I remember correctly, the only common IDed (such as 5/8" or 9/16") bushing that will fit the 55 OD has a very thin shoulder.
I made up some new spring hangers, and my stock shackles and spring bolts are no good, so I was hoping to use a cheap and commonly available bolt for my shackles and spring bolts. 11/16" bolts are nonexistant and 18mm bolts and a new drill bit is $$$$. I tried using a 3/4" bolt since I have a bunch, but it really seems too tight in the stock bushing to work well. I then tried drilling the bushing larger and also sanding the ID and both methods did not work out well.
If what I said is confusing, essentially what I want is a simple bolt/bushing combo that is inexpensive and relatively easy to get and will work with my 55 springs. OR, I need a way to enlarge the diameter of my stock FJ55 bushings 1/16".
Hope I'm missing something simple....
Thanks,
-Tyler
Thanks,
-Tyler
