FJ55 Hub size?
npulver
Metal Messager
Was doing some looking at rims (i change my mind quickly) The two rims im looking at, one is a 4.25 hub bore ( i know im safe there), the second one is 4.177 bore. Did some quick research (on FJ40 since i couldnt find the info for a 55) But Downey is milling rotors to 4.175 on 40 axles. (which i believe are the same as ours) should i be fine using the 4.177 hub bore rims then? (i assume i should be fine)
So for simplicity of those who dont want to read that:
What's FJ55 hub bore size?
