Due to some problems with my old tank, I'm swapping in a new. The old tank has one fuel line that goes to the fuel pump. On the new tank I acquired, it looks as if it was meant to have two fuel lines in the same location. At least there are two fuel outlet nipples right next to each other. Now the problem is I'm not sure which nipple does what. My guess was that one was the actual tank to pump line, and the other was a vapor or fuel recovery/overflow line. The problem with this is that I cannot see inside of this area of the tank to verify if one of those nipples pokes down to the bottom of the tank. So does anyone know if one of these nipples really does go to the bottom of the tank. I do not want to hook up the tank and run out of gas even though the tank is half full.
Also, I was not using a stock tank, so mounting was completely different. It was mounted to the frame, not the body. Does anyone have any pictures of how the mounting brackets and such go?
