I guess this is part two, of an idiot and his wrecked cruiser. This fj40 I just got has had the wiring harnes severed in multiple areas, completely cut in three spots of the wiring bundles. On the passenger side, it is cut near the firewall. I was reassembling it today and ran into a question. There are two different wires that have the same code, solid green with a yellow stripe. One comes from three wires joined to one, while the other is from only one wire. I assume both of these are for the blinkers (1974 with apron lights). Are these two wires interchangable? They have the same color coding and the same gauge.
Also, the instrument cluster was removed and replaced with a different cluster. ONly the different cluster was just thrown in the back instead of installed. What hooks up to the back of the gauge cluster besides the standard cruiser multi prong round plug and the ampmeter lines and the speedo cable?
Thanks, I will get this started tommorrow. Multiple shorts, severed cables, cracked remote starter solenoid, and stuck (and previously smoking and screeming) starter kept it from starting today.
