Well, I think I fixed it!! (but they could just be working now. )
After my 2 hour ordeal trying to fix my dash lights I figured I take a closer look at the fuse this time. Fuse looked fine. Test light showed pwer on both sides of the fuse. Wipers no workie. Then tried my test light with the wiper switch in the on position. The second I touched my test light to the fuse (cold side) the wipers started up.
Pulled the fuse, tested fine. Cleaned the fuse holder with a 3M pad popped fuse back in. Wipers work. turned them on and off a dozen times, they worked every time.
FWIW, the washers were also not working, and since in the wiring diagram, the wipers and washers have a common power point, but switched different grounds, I was suspect of the power soruce, and then the control (only since it is harder to get at!!)
Hope this has fixed it - I think that a full fuse panel clean out is on my list of things to do!!!
Thanks to all those who helped.
