FJ40 Weight -Stock
Try this
This is from my bone stock 74FJ-40
That sounds more like it.
add a 2000 lb trailer and it would be close. The longer the tow vehicle the better.
Just for grins, the gross vehicle weight means loaded with passengers and gear. The net weight is just the weight of the vehicle alone, and comes in at 3470 lbs for an FJ40 of your vintage according to the owner's manual.
http://www.pc.gov.bc.ca/cmg/newweb/GVW.htm
Hmmm, I guess I will have to explore other ideas such as driving it! That would be the adventure I have been looking for. Hopefully not too much of an adventure though. :eek: Lots of work to do before it would be ready for that though!
Not that I would do it again, but I towed my 40 from Philly to NH on a heavy Uhaul trailer behind my old 98 v6 tacoma. A little hairy starting uphill, and definately had to plan ahead for braking, but I made it with no real drama. As long as the trailer has good brakes I would think a V8 durango would do fine.
To me there's no question. Of course your Durango will tow your 40 on a trailer. I;m not sure what your towing experience is, but as long as the trailer is properly equiped with brakes and the 40 is balanced so the trailer is slightly heavier on the front, You should be fine. Just take it easy, no sudden moves, keep it smooth and I wouldn't run over about 60 mph.
Wow
I'm suprised they rented it to you. When I got mine , they had some computer program that they used to figure the towing ability of my Full-sized 1/2 ton Chevy truck that I towed mine with. They seemed hesitant to do it with my setup. I went to united rentals...They wouldn't rent it to me at all. They said I had to have a 3/4 ton truck.
