FJ40 Towing
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
Ok, so I did the search thing - I'm learning. Didn't really find what I was looking for. I am looking at a 1976 FJ40 for my first. I will need to do some towing with it, mostly my ATV which I know it can handle, but also some loads of wood. I can do more smaller loads instead of fewer large loads so that doesn't really bother me. I Think I remember reading that it would not be a good idea to tow anything over 4000#, as that is what the 40 weighs aprox. I also plan on putting electric brakes on the trailer, and perhaps tandem axle to take more weight on the trailer and less on the hitch. However, my question here is...is there a rating on the fj40 for towing? There is no hitch on the one I am looking at, but it has the holes in the bumper. Was there a factory option of a hitch, and if so, did it have a rating? - and where is a good place (ebay?) to find one?
Thanks.
I have never seen a factory ball hitch, but there was a pindle hitch from the factory that fits those holes. There are factory diagrams for trailer wiring, and a hole for a 6 prong connector. That said, I have never run across a factory tow rating in print, nor have I seen anyone quote one, and I've had a lot of interest.
I would tow a 4000 lb trailer with wood on it as you describe, but I wouldn't go faster than 35 mph, and I wouldn't go far. Otherwise, I'd stick to around 2000 lbs. or preferably less. I think you have a good chance of deforming your rear cross member with a heavy trailer during stops and starts.
My FJ 40 came set up for trailering with a homemade hitch that had reinforcement straps that attached to the undercarriage (as well as coil springs on the rear shocks). I have no knowledge of what they towed, but the PO did damage the rear cross member some, even with that setup.
I would put one of the reciever style hitches that are available from many of the vendors out there..
I do not ever remember seeing a specific number, but 3500# keeps popping back up in my head...
A trailer with electric brakes is a good idea, but can lead to overconfidence and a balled up truck and trailer....be mindfull of the tail wagging the dog....been there, done that. :) (743 bobcat behind my 69-40, lifted with 33"s, three speed tranny, drum brakes all around, non-operative surge brakes on trailer 50+ miles of twisty, hilly roads...he he he NOT AGAIN!)
Good luck!
-Steve
You just wait, gimp.:)
I have a rear x-member that has been "tweaked" by something, and my receiver hitch provides the perfect place to stick a long piece of heavy walled 2" square tube to "tweak" it back.
Ed
trailer waight
The user manual in my 79 fj40 that was in the glove box states 2700 pounds max for trailer to be towed.
jimr
Cool!
I have one that bolted in by Downey Off-Road. Receiver type, works well. When I called them and ordered it I had it sent without being painted. I then primed and painted it black. I don't care for the silver powder coat they use. I think this is the link....I hope it works anyway.....go to "hitches and towing accessories" from here....
http://www.downeyoff-road.com/BodyComponents/index.htm
The heavier the load, the more you'll wish you had a longer wheelbase.
Keep it slow and plan FFFAAARRRR ahead.
Thanks all, I think I can manage to keep my loads down to a manageable size. Most hauling would just be the ATV, then in the fall a few chords of wood, broken into smaller loads. I have a small trailer now 6' x 4' and have used it to get wood home, it is only rated at 1500#, so I know I could do it with that if I HAD to, however I would prefer tandem axle with brakes. I believe that having a tandem axle would reduce the tounge weight, and would therefore have less of a harsh effect of the short wheelbase - is that correct?
I like the looks of that Downy hitch - by chance do you recall what it cost? (it says $call) Did the no paint option cost you more or less?
Thanks.
Thanks.
Bruce, you do not want to reduce tongue weight, necessarily. It should be a minimum of 10% of the towed load. So 1500# should have at LEAST 150# of tongue weight. Less than 10% and the whole thing will be VERY out of control.
I think a single axle will be very adequate for 1500-2000#. Just make sure you have the requisite amount of tongue weight. Most "real" single axle trailers are rated for 3500# gross. The limiting factor is brakes. Plus, you need to remember that SWB tow vehicle + SWB trailer = white knuckle ride. IMHO
Ed:)
Hi Bruce,
I believe I paid no more than $79 for it, but don't quote me on that, it may have been $49 (I'm kinda cheap so it wouldn't have been any more than $79). I also don't think the no paint saved me anything. If I remember right, they were on back order from the manufacturer and it would have taken something like 2 weeks longer if I wanted it painted, so I opted for the naked one. Looking at the one in the on line catalog it looks like Downey may have changed vendors, it doesn't look quite like mine, but it is real close.
Do not tow a tandem axle trailer with a cruiser!!!
Nix, Nein and hell no!!!, even if you have 10" greater than stock WB.
A tandem trailer will track straight ahead unless you have the WB to get leverage on it. A cruiser just isn't a tow vehicle unless the weight is under 500 lbs. with a single axle. Towing a tandem axle with 90"'s of WB is very close to suicide. It would not be the smart theng to do.
trust me on this one.
I cut fire wood in the winter, and i have hauled a rick of wood behind my 76 all stock except for a 4inch lift and some 33's and it did fine. And i have hauled my 4wheeler to the deer woods and it was fine. Mine only goes about 60mph with the engine screaming so i dont think going to fast is that much of a problem. But stoping on the other hand PLAN AHEAD LOL
