- Joined
- Aug 4, 2008
- Threads
- 140
- Messages
- 3,478
- Location
- Commonwealth of N.VA
- Website
- www.capitallandcruiserclub.org
Hello everyone
So I sanded off the paint from the top and found all this damage. I know that this rig was rolled about 10yr ago and had a lot of bodywork to it.
This pic is of the front rivets. The cracks stretch between and connect all of them.
Driver side front
Driver side front inside. The crack runs under the cracks in the above pic and is about 10inches long. I know that water gets in through this spot when its raining.
Driver side rear
I plan to rattlecan flat black the fiberglass top eventually. I had also picked up some Bondo-Glass for little imperfections.
The driver side front top looks like it had been smoothed over earlier w/ the stuff. Since the fiberglass is cracked in the inside, I might as well put some fiberglass sheet w/ resin in the inside.
What is the best way... to fix the cracks in the top outside portion? Can i pour some resin into the cracks and smooth it out, or is the Bondo-Glass good enough? I'd just like to know my options. This isn't a show truck...but not a beater either.
Driver side front
Driver side rear
