- Joined
- Mar 28, 2009
- Threads
- 36
- Messages
- 107
I've tried for years to come up with a subwoofer in a cruiser that doesn't take up the limited space in the truck, and I think I finally found something that works for me anyway. Most of my passengers are under 5' tall (kids), so this install was perfect. If you have taller passengers, maybe not so much.
So I did some research on pancake powered subs, and the Blaupunkt gths131 had everything I wanted/needed. Cost me a bout $100 or so on Amazon. The case is made from a heavy cast aluminum and is 2 pieces. You can unbolt it and crack it in half. So I drilled 4 holes through the passenger floor board and mounted the speaker face down using some 3/4" spacers to keep it off the floor. With the speaker side mounted to the floor (pic 1), I then cut a piece of 1/2" oak plywood to size (little bigger than the sub itself), then drilled and tapped the backside aluminum case of the sub to mate to the plywood, being very careful not to have bolts driving into the electronics. Screw the sub back together, test fit the plywood, and upholster, which in this case was a carpet the wife didn't want, so the truck got a floor mat makeover.
