fj40 Starter / Ignition Problem
I've been noticing that when I start my 1977 FJ40 that I usually have to wiggle the key to get the starter to engage. When I do it starts fine. When I shut it off It momentarily engages the starter again and I can hear it grind very briefly. I was suspecting a bad ignition switch.
This weekend I was out hunting and it started and I drove a short distance and all of the sudden heard a hellish noise/squeal/grinding and smell smoke. As fast as I can get slowed the noise stops and the smoke clears and the truck continues to run as if nothing happened.
I drive back to hunting camp and shut down to inspect. Turn the ignition on and nothing. The wire between the solenoid and the starter has melted until open. Jump across the melted wire with a screwdriver and turn the ignition on and nothing...should say sparks and solenoid clicks, but no starting. All other electrical works fine. Headlights, turn signals, wipers, heater fan, radio are all ok.
Roll it to start it and it starts and runs fine. Drive it home 150 miles with no problems. Charging systems seems to be working fine.
I suspect a bad ignition switch may have engaged the starter while the truck was running. I'm planning to replace the starter and ignition switch but was wondering if someone has experience with this and can offer any advice.
Am I on the right track or am I missing something?
Timberpig
I think you are right on with your diagnosis. The sloppy ignition switch is putting power on the starter contact as it moves around.
