I have a 71 FJ. I had to remove the passenger seat to replace the gas tank, so I remember a bit about it. The legs are different lengths. The back two legs, I believe are the same length, or very close same length to each other. The two front legs have to reach further down for the floor (I think), but on mine they weren't the same length. The one near the door is longer and goes right to the floor. The one toward center of vehicle is shorter, so does not reach the floor, but in mine, there was a metal pipe that made up the difference to the floor, the bolt went through the "foot" of the leg, through the metal pipe and through the floor to right above the transmission, that one is HARD to get unbolted. Mine may not be the same as yours because the "tub" in mine is a replacement aluminum aftermarket, so could be that it isn't exactly the same in that exact spot as the original tub. ANYWAY: Just because they are different lengths does not mean they will for sure not work. If the alignment is way off of the holes in the floor, that is a whole different issue, I can shed no light on that.
