FJ40 rollbar
Coldstream, BC
I have a 1984 FJ40, which is in the process of restore. I want to put rollbars/cage in it. Is it a good idea to try to keep the bars so that the original top will also fit on? It's not going to have A/C and it's not a DD. I just want something fairly solid.
Does anyone have the measurements of factory rollbars? I saw some photos where they were welded onto the top of the wheelwell and that didn't seem very sturdy.
Just looking for any thoughts. Thanks.
Run a search on here and Pirate4x4.com for days and days of cage tech. Also look on the Ih8mud home page for cage ideas, and the tech links.
Yes, make it so that you can keep the top on, prolly best to have the top on and off a couple time through the build up of it to check clearances etc...
Welcome to MUD!!!! Wakeskater. :grinpimp:
Yeah that wheelwell mounting SUCKS. When my Clemsoncruiser and I rolled in his 40 that factory bar pushed right through the wheelwells. No support to the frame with like 4000lbs on it isnt a good combo.
But it did it's job rudy...you're still alive...believe it or not the only reason it pushed thru is cause there was some rot down there....if you wanna keep the stock roll bar just make a plate and mount it underneath and then send a tube down to your frame.
I looked at that the other day on my rig, I thought it might interfere with wheels under articulation. Haven't looked to hard yet though:o
I think you might have to do some tube bending...you might have to do some creative thinking in order to do it....but I'm confident that it can be done. Down the road as I get closer to puttin in a full cage attached to the stock I'm gonnna look into attachin it to the frame.
Seems like all you gotta do is bend some tube to the form of the wheelwell & mount that to the rearmost & forwardmost area tied to the frame. Then cut some plate to mount to the underside of the rollcage, where it mounts on the upper wheelwell. Then, just tie the tube to the plate..... Hmmm.....
