FJ40 rear diff oil
Costa Rica
Hello,
I have a FJ40 of the `67.
I installed a rear diff locker (lock right) and i used the same oil that the diff had without locker (I think it was 90W) and all works fine...
Then I decided to change the diff oil and I fill it with Castrol hypoid GL-5, I ran the car and I began to heard the click click click all the time (with the other oil I heard that only in turns), it sounds very low, but sounds always. I`m afraid to damage the locker!!!!
The question is: will the hypoid GL-5 works with this locker?, or do I need to change the oil again?
Thanks:cheers:
You are running a thinner oil than you originally did. The way to quiet down lockrites is to run a heavier oil. I run a mix or 90wt and 140wt or whatever is the next step up from 90wt and mine is nice and quiet. I believe in the owners/install manual they even mention this.
Just noticed this is your first post, Welcome to Mud!
Yes, this is my first post and I`m happy because you`re helping me. I`m from Costa Rica:beer: , Central America, and we have a lot of LC here but there aren`t too much lockers, so I don`t know who ask for an advice.
Tonight I`ll check the psi of the tires, good idea!!!:idea:
If the psi are the same, could you think that I can add some kind of additive to the oil?
:bounce2: :bounce:
