FJ40 Parts Located in CT
Lincoln, CA
All parts are located in Rockfall CT - you may call me at (eight six zero) - 810 - (two four seven one)
or email me at anthonydelvecchio287(at)gmail(dot)com
**also i'm new at posting prices for things so if you see something but don't like the price e-mail me and we can work something out
Pictures of things can be found at Pictures by antfj - Photobucket - i think everything is there if not just ask
big stuff
76 hood - (free) needs lots of work
75 2F Engine - ran but rough (free if you come get it) - parts available upon request
76 front doors - $50 (need lots of work)
76 rear amby doors - $25 (need lots of work)
78 hardtop in okay shape modified with half amby doors which need some finish work - $100
driver fender - $30 some rust and a dent
74-earlier apron - $10
later apron - $10
68 bezel - $10 4 small rust holes
small stuff (prices include shipping for that individual piece.. if you get more than one thing the price will be lower)
76? gas pedal with throttle attachment yellow zinc and new pedal pad - $75
78 clutch and brake pedals with assembly - $40
complete smog set up - $100 looks good only slight surface rust - includes everything seen in the pictures
76 washer bottle w/bracket - $15 no motor
76 coolant bottle w/bracket - $15 no cap
2F valve cover - $30 good condition
Man-a-fre heat fluid riser - $40 (comes with used gasket and is slightly ground down to allow clearance for headers)
76-77 Wipewash switch - $20 face restored
76-77 fan pull switch - $20 face restored
76-77 hazard switch - $20 face restored
75- fresh pull - $25 face restored cable in very good shape
76-77 fan pull switch -$10
76-77 hazard switch - $10
75- choke cable (2) need work - $5
77 fasten belts/brake light w/mounting bracket - $25
headlight trim - $5 solid chrome is faded
headlight buckets (partial kit) (2) - $5
75-78 steering wheel brackets - $15 blasted primed painted with rustoleom
76 horns (pair) - $10 rusty but worked when pulled
aftermarket pedal assembly - $20
75-78 door strikers yellow zinc - $35
toyota emblem rubber - $2
kick vents - $10
76 wiper motor cover - $15 good condition
76 emissions controller - $5
77 emissions controller - $5
76 seatbelt buzzer - $5
shifter boot w/metal ring - $20 (two small slits)
76 rear view mirror - $20 good condition
heater valve (firewall) doesn't work? - $5
8 used shackle bolts - $15
jack rod mounts - $10
1 door stopper - $15
Heater hoses for inside cab - $20 for no rear heater comes with two copper heater pipes, two plastic covers and two rubber hoses
heater blower grate - $5
dash pads - $10 no clips on back.. would have to be glued on
steering wheel cover top - $5
balancer splash guard - $10 pretty rusty
wiper assembly - $25 (one of the plastic clips is broken)
2F head - $30 unknown condition (ask about shipping)
2F bellhousing (2) - $30 (ask about shipping)
2F Flywheel (2) - $30 (ask about shipping)
78 exhaust manifold - $40 couple broken studs that are sticking out.. but broken no visible cracks in manifold (about 25 bucks to ship)
2F radiator - $30 worked when pulled no leaks (will not ship)
Ant- how's the dash in the 78 cowl? If it's clean I could prob use it. I can come cut it out or take the whole cowl if need be. I'll prob call you next week to pick through the pile. I'm on vacation till next weekend. Thanks, Josh
Hey Josh - I'm around all day every day but tomorrow is my dads birthday so probably not tomorrow. Not sure if you still have my number (its up top) but feel free to give me a call when you want to come around - the dash on the 78 is perfect with no extra holes if i am recalling correctly.
Also everyone your PMs have been returned
**note: e-mail me or reply to this thread if you can my PM box is reaching its limits.. thanks!
Anthony
Ant- If rjc doesn't take the '76 front I will for sure. If the '76 hardtop still supports itself I'll take that too. I'll give you a ring tomorrow.
Pm answered and paypal sent your way.
Re-did the paypal thing to your other email. Should be good to go now.
Are parts still available? PM sent.
hey guys this is an old thread however most of the parts are still available. I'm going back to CT in early march so let me know now if you want me to look for something!
Thanks,
Ant
