FJ40 leaky transfer case - seal sizes?
Hi all,
My '82 FJ40 has a leaky transfer case (amongst other leaks everywhere :-) ).
I have not been able to establish exactly where it leaks because everything is wet and dripping.
As a start, I would like to replace the front and back propshaft-flange oil seals on the case.
So, the questions I have are:
What size oil seal is needed for these?
Is it easy to get the propshafts and flanges off without special tools?
Is it easy to replace the seals?
What else 'normally' starts leaking on the transfer box?
Kind regards
Bernt
berntd said:
Hi all,
Kind regards
Bernt
I've replaced the rear seal on my transfer case so I'll comment on that. It's extremely easy, but be sure to pick up a good seal. I ordered one from Spector Off Road and messed it up trying to install it. I ordered one from the local Toyota dealership and was amazed when I picked it up. It was much beefier on the metal part and was very easy to drive in. I would suggest ordering the seal from C-Dan. I'm adding up a list to order from him right now. :D He's a great guy and will hook you up with whatever you need for the job.
i got my stuff from napa and it was in stock go figure!
check at www.napaonline.com just search for your year and model pretty easy and they have the speedi sleeve's too if needed.
good luck!
oh and its pretty easy to get to and no special tool's needed. i dont remember but you may need a new staked nut (spelling) not sure its been awhile, or reuse yours but i think napa had them too and they are cheap. do you have a manual either Haynes or factory service manual ? napa has the Haynes for like $16.00 bucks get it.
