fj40 and fj55 frame widths?
Folsom, CA
OK, don't flame me to bad for a newbie question.
Are the frame rails where the motor mounts on a 40 the same width on a 55? The frame rails on a 55 widen out behind the motor, this I know, but is the frame the same width on both where the stock engine mounts are on the front of the engine?
So if I have some really nice motor mounts that sit on top of the frame rails, can I use them for either my 40 or 55? ;p
according to my 78 factory manual, the frame rails center to center on the 40, 45 and 55 is 686mm
RIGHT ON! Thanks. Now I will just need to get a second set of mounts made because the source for the 'over the rail' mounts is no longer.
" the source for the 'over the rail' mounts is no longer."
Do I read this as bob firestone nolonger makes the mounts?
"the 73 55 frame i have is 3/4" wider than my two 40s"
Checking further in the manual,
center of frame to center is 686
but
the outsdie deminsion onl the 55 is 736mm the 40 is 726, so the 55 has a wider frame
1/4" Hmmmm that might be doable.
Bob never did make the mounts. He is just the middle man. He has a friend that is a custom fabricater for a large corporation. The friend makes the mounts and Bob distributes them. The friend has moved on to making other 'stuff' more profitable than cruiser stuff. So I understand anyway.
The rail itself would appear to be wider on a 55 than the 40. Just thinking about it, i would say that the driver and pass rail is 3/4 inch wider than on a 40, since they both have the same center line. The 55 would be 3/8 wider off the centerline on each side. Ige, do you have a rail measurement on the 55 and the 40?
