FJ40 350 Conversion Question
This is probably a dumb question but here goes...
I am getting ready to get a 350 and slap it in the truck, but here is the question.
The transmision and transfer case!?!
Is it possible to use a full chevy 4x4 tanny and tc? Simply get rid of the toyota tc.
How about using a 700R4 and it's tc?
Any info would be greatly appreciated.
My FJ40 has a 350 and a gm tranny, but it has the stock toyota tcase because your rear axle is offset. There's a small adapter in between the gm tranny and toyota transfercase. I bought it that way but I'd be willing to guess that Advanced Adapters makes what you'd need.
The problem with using the Chevy t-case is that the rear LC axle is offset. This will cause you drive shaft problems due to the angle. You can buy adapters to use the LC t-case but I assume that you are trying to save the $$$. Another option if you wanted to run the Chevy t-case is to use a centered axle. You could probably use a toyota truck rear end but people argue that it isn't as strong as the LC axle.
One question to think about when running the Chevy t-case is that out put is a slip yoke right? Wouldn't you rather have one which isn't?
