I've done the searching, looked at builds, read the disc brake conversion writeups, peered over the archives, and studied my service manuals. Toyota has never published knuckle ball or knuckle dimensions/specs . The two outfits currently manufacturing knuckle balls (or bells) don't share any info either. BTW, in Toyoda speak, they are neither balls nor bells, but Front Drive Ball Joint CASES, and the early ones had their own part number, although they were part of an assembly and not available separately. The 40/50/60/70 series all have the same 1deg of camber and 9deg30min of king pin inclination, but there is some variance in caster.
The question: are FJ25 knuckle balls the same dimensionally as the 40/50/60/70/minitruck series versions, and has anyone ever used FJ25 knuckle balls with a disc brake conversion, as in--will a 40/50/60/70/minitruck series disc-type knuckle properly fit a FJ25 knuckle ball?
