FJ E-Locker fitment question??
Inlet Beach, FL
A buddy of mine has a factory rear E-Locker from an FJ that he's looking to get rid of. What all will this fit other than an FJ?? Any help would be great.
It should fit another late-model 8" Toyota rear diff, 4Runner, Taco, etc. but it has to come with the entire 3rd member as it won't just bolt on to an existing non-locked 3rd.
How much would it be worth with 3 teeth broken off the ring gear??
Hmmm... don't really have an idea as I've never bought one or looked at them, but I have recently re-geared my FJC after blowing a rear ring gear and can advise you that Toyota OEM ring gears are crazy expensive, like $850 just for the gear! You can get a good aftermarket ring and pinion for 2/3 of that but I don't know if you can get them in the stock ratio.
I think the hole in the rear axle housing has a special cutout for the elocker, I'm sure any of the differental vendors would give you a better idea of fit, worth and cost to fix.
IIRC it's the same diff as the locked 4runners, Taco's, etc. With mods it will fit most 8" housings, the exception being the late Taco, Tundra, etc, commonly called the 8.4" diff.
Erik's Toyota Differential info
