- Joined
- Jan 29, 2012
- Threads
- 1
- Messages
- 6
A noob to the FJC forum but been around awhile in the FJ80 forum so flame away if you must.
Bought a used '07 FJ on May 22nd 2 days later check engine along with almost every warning light came on. So mad I didn't even waste time to pull codes just hauled it to dealer while still under 60 day warranty. Told me it was a catalytic converter so they replaced it on May 29th. June 24th decided to change plugs not knowing how long since last change. FSM calls for Denso K20HR-U11, what I pulled out were Denso platinum plugs PKH20TT. I cross referenced Denso website and decided to go with iridium. Denso recommended IKH20 so I put those in. I drove about 600 miles and all was good then July 4th started up the FJ and check engine light came on along with all the other warning lights. Hauled it back to dealer, service manager called and told me they needed more time with it but they think it is the knock sensor. They want to consult with someone before tearing apart the motor to replace it.
This is a long way of asking,......do any of you think it could be the iridium plugs? I mean if I need to go back to the platinum plug or what the FSM recommends then it'll save a lot of heart ache. What to y'all think?
