FJ Clutch problem
in the bush
Help please ?
I've just acquired an old unreg FJ for use on a farm. Not sure what year.
Got it going and drove around fine for a while, but now the clutch has completely gone.
The pedal just goes in and out with no resistance and doesn't activate the clutch.
I can still force it into gear without having the clutch, but need some basic guidance on what to look for and how maybe to fix ?
Please be kind - I know little about mechanical things but hoped I could check out a couple of more obvious causes before giving up. It won't be viable to spend much since the ute was a freebie.
Any help gratfeully received.
Fooseddie,
You have posted in the wrong section. This will be moved to the 40 Tech or maybe the 45 tech section.
From the 1st picture you posted, it looks like the clutch cylinder is leaking at the firewall. On your firewall, at the far right side is the brake booster with a brake master cylinder attached. It contains fluid for the brake system. Just to the left of that is your clutch master cylinder. It also contains brake fluid but it appears to be leaking (dark red area around where it bolts to the firewall.) You'll need to get a repair kit or a replacement.
-B-
Right, it sounds like you pumped the clutch fluid out. The clutch has a hydraulic actuating system similar to a brake system. There is a master cylinder which is pointed out to you above and a slave cylinder at the end of a steel line from the former, down alongside the clutch housing. It DOES look like the master cyl. is your culprit.
By the way, that truck would be worth several thousand dollars if it were in the US. It appears to have original parts that individually are very much sought after even in your country. Don't give up on it too quickly.
You should replace both the master and the slave at the same time. They have equal wear on them, you know. Rebuilds have very mixed results.
GL:beer:
Ed
PS, your clutch is on the wrong side;)
Thanks so much for these comments.
So if I understand correctly - I should try to drain the fluid, and then refill it - is it really brake fluid that goes in the cylinder because that's what it says on the lid ? Any tips on which bit I undo to drain the fluid as all the nuts on that line are well rusted so I can tell it's going to be a fight ?
But if that doesn't work I should replace the resevoir itself at the top ?
I couldn't really tell which bit could be replaced at the bottom end. It seems to go into a small actuator type thing which I guess is the slave cylinder. When I pump the clutch in and out, there's a tiny bit of movement at the bottom end, just twitching really, but not sure how much it's supposed to move since I didn't look at it when it was working.
I'll try and get a photo of that part this weekend when I'm next at the farm.
By the way - can anyone tell me what year model the truck is ?
First question: Is there fluid in the reservoir? If so, does pressing the clutch pedal cause a leak somewhere? If there's no obvious leak, you may try adjusting the slave cylinder (right near the clutch plate).
If there's a leak, you're looking at installing a new master/slave cylinder anyway. Hey, you didn't pay much for the vehicle, right?
There is fluid in the resevoir - it looks about 2/3 full.
I couldn't see any leaks squirting out when pumping the clutch pedal, but on reflection I think it might have been a bit wet/oily/fluidy looking on the actuator at the bottom. It was moving so little I wasn't even sure if I was looking at the right part. Now that I understand a bit more what I'm looking for - I'll double-check.
And I'm happy to spend a bit on it, this truck is a monster - you should've seen it go - it was unstoppable !
And I love this forum already - all the help is inspiring me to have a go a fixing it, and when I get stuck I'll know what to ask for when I go to the shop for parts !
fooseddie,
Stop us at the point where we become insulting but you mention you are new to DIY maintenance so we have to start with the basics.
If that dark spot around the clutch master is brake fluid (from the clutch master resevoir) then you should haved cleaned it up good with soap and water before leaving the farm. Do the best you can to clean it when you return. Brake fluid is extemely caustic to paint and will eat right through your prized FJ45's paint on the firewall down to bare metal. As you are working on getting this fixed, quickly clean up any spills. Use copious amounts of soapy water.
-B-
That dark patch under the master cylinder in the photo is rust, not fluid. Maybe in the past it dripped there but now there's no obvious wet spots in the engine bay from fluid that I could see, but there are lots of rust holes !
back in action
Thanks for all the comments, I have finally got around to bleeding the clutch and surprisingly it worked !
I ended up buying a repair manual which described how it's necessary to slowly pump the clutch pedal until all the air has gone. I tried this for about 3 resevoir-fulls of fluid and the air just kept sucking back and forth. Eventually I just let it flow through gravity with no pumping and it was fine.
I'd be interested if anyone knows why this happens ? Have I done it wrong, is the repair manual wrong ? Does it matter ?
Anyway - I'm getting cocky now and I think I'll try the brakes next.
Make sure to use clutch fluid in the brakes.
