Fj-80 tie rod tube adapters
Orange County
Getting some high steering arm that run with Fj-80 tie rods. But don't have any links/drag link for them. Plus I need a Chevy end for the pitman arm. I was trying to find a tube adapters on a few places. But cant seem to find one. Looks like they just tapped on the material. If thats the only other way what size tap is it?
ok reviving this thread.. Gotta question related to this.
Does anyone sell a 21mm weld insert, lh and rh
and 21mm Jam nuts LH and RH
I've only found 23mm.. Before you flame me for being in the wrong area, it'll be for a custom relay rod utilizing Fj60 TRE's on my FJ45 using the FJ60 power steering box so I can keep the PTO winch.
Plan to utilize FJ60 TRE's and Steering box but everything needs to be shortened. And of course I can have one built just thought it'd be easier to have some inserts avail. Will have one built if needed.
Just slowly lining up parts.
TIA..
Check low range off road. They had a bunch of different sized weld in tube ends. If you go w those, be damn sure you weld em with the rod end threaded in the threads... I had to actually send mine out to get re tapped cuz the threads warped so bad. The cost of those odd sized dies was phenomenal.
HTH!
Will give em a call.. Thanks all..
Try Bud at BudBuilt for the 21mm stuff. He had the jam nuts a couple years ago and I think he had inserts as well.
