For Sale FJ 60 parts
Status
Not open for further replies.
Make me reasonable offers on anything listed. Don't really want to scrap these parts. 1983 truck had 249K miles when retired. Driven by 2 children as first vehicle. Never towed anything or been off-road. Driven 35K miles in 10 years.
Can view parts at http://photobucket.com/petrolheadfj60parts
Rear axle w/stock springs- $100
4 speed tranny- $250
Transfer case- $200
All glass(no cracks or chips)- OFFER
Rear lower gate- $75
Tranny/transfer skid plate- $OFFER
Alternator- $70
HVAC fan- $25
HVAC control panel- $25
Glove box & door- $25
HVAC/Radio dash panel w/rear heat/defrost switches- $25
Intake manifold- $80
Exhaust manifold- $80
Cylinder head w/rocker assembly & valve cover(reman head w/20K miles)- $200
Water pump w/pulley- $25
Aftermarket radiator w/shroud- $70
Radiator fan w/clutch- $25
Clutch master cylinder- $25
Air cleaner assembly- $40
Engine compartment cooling fan(fender mount)- $40
Coolant thermostat housing- $30
Rear driveshaft- $75
Carburetor- $50
Carb. linkage & brackets- $25
Emission valve rack w/bypass valve,vac switch valve,HAC valve- $45
Emission control box- $40
Left frt. corner lights- $35
Tire change jack w/2 rods- $25
Windshield washer tank(no cap)- $25
Frt. headrests(brown)- $40 for both
2 Window crank handles w/clips(brown)- $20 for both
2 Interior door handle trim covers(brown)- $20 for both
Frt. fender vents- $25 for both
Rear D pillar vents- $25 for both
Fuse box cover- $10
2 Battery fuseable links- $25 for both
interest with front DC drive shaft
how much for the shipping cost to indonesia?
do you have p/s pump bracket
and this one, i think i get it from you
thanks
benny
thanks
benny
I'll have to do some checking on the shipping for the frt. driveshaft. Yes, you got the alternator bracket from me. I do not have a power steering pump bracket.
Thanks
Do you have the long brake line that is on the front axle? Shipped to 93111.
thanks
Dazed
thanks
Dazed
Maybe depending on an inquiry for the frt. axle. I'll PM you when I know.
Kelly
Do you still have the alternator bracket like this
I take the front double cardan drive shaft
I wait the alternator bracket, if have please sent together
Thanks
Benny
thanks
benny
Okay the front driveshaft is yours. You already got the alternator bracket from me. Thought you were still looking for the power steering pump bracket which I don't have.
how are the seams on the lower tailgate? if they're good, I'll take that and the fusable battery links. Any chance you have the top pass side chrome corner for the windshield?
The seams where the tailgate skin is welded on the back to the inner gate are very good, no rust. I do have the chrome corner for the windshield(no charge).
PM me your zip code and any shipping preference you have. FYI the gate alone weighs 30 LBS. so with everything packaged with protection total weight is approximately 38 LBS.
plastic bolt cover for the rear view mirror?
Fo you still have side marker lights. Do you think they will work on a fj62. If so I'll take them please.
Sent from my iPhone using IH8MUD
Still have them, they should be the same for both 60/62 series. PM me your zip code for shipping costs. Thanks.
Looking for the air cleaner intake hose that will fit an '83 FJ60. (The hose that goes from the air cleaner to the front support.)
Status
