fj 60 axles & 87 2f ?
SO.WEST,COLORADO
Can you tell, w/out tearing it apart if it is a ff or not ? Are 60 axles wider than 40 axles ?
Is there any difference between a '78 2f and an '87 2f ? Meaning can i bolt up an 87 2f in my '78 40 w/no mods ? Thanks, Mike
Yes.
A full-float rear axle assembly will have a bearing hub protruding through the wheel, similar to the front axle.
A quick search out here will reveal plenty of pictures on the topic.
Yes, 3" longer on the long side, iirc.
Nothing of any real significance externally that will create problems. You will need to keep your flywheel housing, as the 08/80 and later 40 and 60 series flywheel housings do not have mounts on them like the earlier style.
Good luck!
-Steve
