FJ 55 Gear Down
I have a stock 1969 FJ 55 with PTO winch, 3 spd on column, dash mounted TFC controls. The low range 1st gear on the 3 spd transmission is already to 'high' to suite me and I plan on changing the tires to 9.50x33's. For spare parts I have all of the running gear, engine, etc. from a '78 FJ 40 and a floor board 'hump' for a floor shift to fit the '55. Options that I am considering; 1) Install the '78 USA 4 speed and adapt to the '69 transfer case, 2) Purchase & install a 4 spd "non-USA compound low - fits 3 spd to 4 spd conversiion with course output shaft" (SOR description) transmission, 3) purchase & install a SM 465 or SM420 GM transmission and adapt to the 3 spd (or 4 spd?) transfer case. I am not trying to build a rock crawler, just a more trail worthy '55 with decent highway gearing. I would like to keep the PTO winch. Does anyone have any thoughts or experience regarding costs, difficulty of change, final gear ratios, etc?
P.S. - I have a '78 FJ 40 with a non-USA compound low 4 speed adapted to a 3 spd TFC, 33" tires and 4.88 gears that I am very satisfied with
I think that you answered your own question right here....
If you are not going to get carried away with this 55 off road, then I do not see why you would want to put a 420 or a 465 in it. The Toyota trans(both USA and non-USA four speeds) are great, relaible transmissions.
Good luck!
-Steve
I completely agree with Poser. dont go to far if you arent planning on wheeling it hard. If its a driver, go with a Toyota h42, and 4-speed case.
If you want a bit more out of it for wheeling, but still be easy to drive, go with the H41. I try and stay away from 3 speed cases in anything I drive alot, since they are most definetely noisier.
-Brett
another agreement here,, you just cant beat the drivabilty of the the cruiser trannies. H41 is a great upgrade for trail riding and if your not getting into the rocks with it just build it simply and have fun.
Thanks for the advice. I have two each spare H42 transmissions and 4 spd TFC's that I need to evaluate the condition of and also the 3spd TFC in the '55 when I take it out. I have done the math on the low-low ratios. The H42 with the 4 spd TFC does not have much advantage from my stock setup in low-low, but the other combos look OK.
