Recently I was 4wd while out camping in the bush. I had been constantly stopping and going turning engine off etc to take pictures and such.
Finally when I came to my camp stop and turned the ignition off the engine did not shut off. I took the key out and everything and nothing. Finally I shut it off by putting it on gear. I turned ignition on and engine started, but once again when turning it off engine did not shut off.
The next day the car did not start at all. Engine was cranking and battery was at 12 volts plus it is 4 months old. I finally got the car started by putting it in reverse and clutching out quickly and stepping on the acelerator. When I finally made it home about 5 hours later, it did not shut off. When I finally shut the engine off I tried starting it and it did start. I waited for an hour and tried starting it again and it did start, but again will not shut off. Finally the next day I tried starting it and no luck. I check most of the wiring and everything seems to be in order.
Where do I go from here? How do I check to see if the ignition rack is faulty?
cheers
rafa
cheers
rafa
I believe your ignition switch is to blame, probably worn out from all the stops and starts. Good luck.
