fixed my no start woes
Newfoundland
After testing every f***n fuse and relay i could find, my coclusion was a broken power wire, somewhere between ignition and starter..(i ran an ohmeter to make sure) .so i ran a new one yesterday, pretty easily. Once again this vehicle has become as reliable as i want it:) I do not know where the wire failed,but it wasn't at the connector, so I cut off and used the original connector, soldering a wire to the existing one, then heatshrinking around it, not quite that fancy at the ignition, but after seeing the mess up under my dash, why not add one more wire.
happy holidays :beer: :beer: :beer:
Good Job! :cheers:
Hmm... make sure I understand... You replaced the wire from the battery to the starter?
IIRC there is supposed to be a fusible link in that line. I.e. it may have failed because it was supposed to. And if the above possibility is correct, you may have put a non-fused solid line in for the starter...
You probably didn't do this and I'm just being overly cautious. However, unfused cables can be dangerous, so best to just lay it out there.
Glad you were able to narrow it down!
sounds more like he ran a wire from the ignition switch to the starter motor. Any chance the truck once had an aftermarket alarm in it, or even the factory one and the break in the connection is there?
yes the truck had one of the dealer installed alarms, I checked its relay and tried a few wires...everything seemed good, this truck also had one of those Prolock Disablers...another bunch of spaghetti under the dash, as well as wiring and relay for DRL's which were needed in canada back in 93 when it was imported...all this mess seemd to still work...although i percieve many future headaches, I am pretty sure the problem laid in the black wire with red stripe going from my igniton to starter...at least until i am stranded again and look like an ass:doh:
