Fix for central bonnet flex (flutter)
Hello all,Thought I’d document my fix for the middle of my bonnet flexing when at high speeds, in case anyone else has a similar issue.
The issue:
A common problem with KZJ78s appears to be that the adhesive that bonds the bonnet frame to the skin fails after 30 years. This causes the frame to drop slightly and allows the skin to flex at high speeds (which is very annoying).
The fix:
The frame needs to be bonded back to the skin carefully so you don't cause bonnet skin distortion or witness marks of your adhesive in the thin bonnet skin.
Materials needed:
- Metal trim remover tool (the plastic ones aren’t strong enough)
- Up to 14 bonnet insulation clips. Part number: 9046709014 (if ordering in advance, I’d buy 14; I damaged 11 of them in removal)
- Wax and grease remover
- Terson MS222 Anti Flutter Sealant (Important to use this stuff over normal sealant/silicone as it doesn’t expand or contract once dry and so won’t distort or mark your bonnet skin. Buy 2 if you really want to go to town resealing the skin to the bonnet, or just 1 will be fine, as that’s what I did. Available from eBay for like $25.
- Standard cartridge gun
- Gloves, rags etc
- Optional: foil tape for repairing the sound insulation cover.
Steps:
1. Plan to do this job at a time when you don’t need to drive your car for at least 48hrs.
2. Remove the sound insulation cover by taking out the clips.
3. Clean the underside of your bonnet with wax and grease remover, focusing on the skin where it joins to the frame. Scraping the old adhesive off where it has failed carefully is advised too.
4. Once the bonnet is clean and dry, apply the MS222 sealant in the areas where the adhesive has failed. Ensure to pump enough in that the frame and the skin are both connected by the sealant.
NOTE: DO NOT attempt to push the skin or frame together or clamp them while the adhesive sets as you will distort the bonnet. Join them together in their natural positions.
5. MS222 sets via humidity, not heat. The manufacturer states it dries at a rate of 2.5mm per 24hrs. The biggest gap I filled was 7 mm, so I tried to wait at least 48hrs before driving the car. Definitely don’t drive it over 60 km/h for 2-3 days, and don’t drive it at all for at least 24hrs.
6. While you wait for the adhesive to set, you might want to patch up your sound insulation cover as the foil probably has deteriorated.
7. Install the cover with the new clips after the adhesive has set, and happy days your bonnet won’t flex anymore!
