Fitting size for Spider Grease Fitting?
Vermont
the spiders are original.
Sleeve yoke grease fitting was a #7, not so spider grease fitting. 1/4 is close but slightly too big, anything smaller in my kit is too small. What size is it?
All the grease fittings, called "Zerk" fittings here, were the same on my stock Land Cruiser, 1993. Some of the ones in the drive shafts were hard to get to, unless the drive shaft is turned just so.
Hope that answerers your question.
The grease fittings on the spiders are pressed in, come out pretty easily with a twist and pull. I swapped the original fittings into the NAPA spiders.
