Fish plating
hey all been a while since my last post i was building a spring over 75 series the build up thread is on here somewhere anyway I've changed direction and am going coils front and rear using 80 series housings and 79 series coil mounts/ brackets etc I wasn't going to fish plate the chassis where the coil and shock mounts weld to but then I noticed that the 79 series chassis that I cut the coil shock mounts off had a sleeve on the inside of the chassis where the mounts where (75 series don't have these) I'm not sure why maybe to stop it from twisting? 80 series also have these sleeves in the same location. I'm now thinking I should look into fish plateing my chassis before the coil shock mounts go on so what's everyone's thoughts to fish plate or not?
Hi all,
NSALT, I would suggest re-posting this question, a little more clearly written, in the "Hard Core" section. Think you would get a better response rate over there.
Regards,
Alan
Here is some free full stops .................................................................................................................................................................................................................................................................................................................................................................................................................
