First Valve Adjustment
I have plenty of experience adjusting valves (on all three of my bikes and my Porsche). Every vehicle I own has some easy way to rotate the flywheel to reach TDC with a wrench or something. The FJ40 is a different beast for sure.
My first attempt was to put it in 3rd gear and engage the 4wd in hopes that I could rotate the front right wheel while looking at the dizzy / flywheel. It would rotate about 5º then stop moving. I was being lazy and did not remove the spark plugs so maybe it was just too much compression. I tried turning over the engine a couple times with the starter to see if I could get it close, but that didnt seem like it was going to work.
So engine running ended up being the way to go. I would run the engine, insert the feeler gauge, and note which ones needed tightening and loosening, then turn the engine off and repeat. It took probably 20 rounds to get everything feeling right. Also beat the s*** out of a feeler guage, but it was a chap one that is basically disposable.
It took a little while of playing around until I got the feel of it, but its definitely the way to do it IMO.
This morning I went to start it up and it was much harder starting and running than it was before. Today was a pretty cold morning (for SF). My startup process is to generally pull the choke half way out, give it a couple pumps of the gas pedal, then turn the key with no gas. If it is still not starting right up I repeat the process with the choke pulled the rest of the way. It did start with no gas but took a couple more revolutions than usual and required the choke all the way out. And it ran noticeably rougher than it typically does for a minute or two before starting to purr.
Now my assumption is that the PO adjusted the valves cold. They are much quieter now, and I had suspected a few were loose. They were. It is running wonderfully once it is warmed up, but rougher when cold.
Is this to be expected?
Thanks.
I'm not sure about your current running condition, but if you remove the plugs you can easily rotate the engine using the crank pulley nut and a 1 13/16" socket. You can get the socket wrench in front of the grill and bezel with a 12 inch extension. Rotate the engine clockwise.
You may want to adjust the valves using that method and see if anything changes.
When I was poking around, I figured something down may be able to be cranked. Good to know. May try that tonight. Thanks.
you can also put in gear and rock the 40 back and forth to get them where you want them
or crank the starter
I do recall that adjusting warm and running is the correct way to do them. I got a neat Snap On tool that works wonderful for that
I've always been able to turn it over to TDC for adjustment by using the factory jack handle as a crank, engaging the cranking ears on the pulley nut. I've got good compression, but it's still not too difficult with the plugs in.
So based on this, if I am seeing the line in the flywheel, and the dizzy is pointing just shy for the midway point between plugs 4 and 3 I have Cylinder 1 at TDC for the compression stroke correct?
or does that just let me know C1 is TDC, and I would still need to establish if it was compression stroke?
valve_01-jpg.246998
A great big nix on adjusting while the engine is running. Nope.
The engine must be at operating temp, cooled down to where you can touch where need be. Query on my recent posts and you'll see where I posted the 'bump' method provided to me by Jim C, a renowned mechanic on this site with a vast knowledge of cruiser repair/rebuild expertise.
Found it: https://forum.ih8mud.com/threads/top-speed-indicative-of-some-worse-problem.823638/#post-9445114
I made the job easier by pulling the 0.008" and the 0.014" feelers from the multifeeler tool and putting them on a loop of a small zip tie so I do a lot less fumbling for the right size.
I do wish I had that snap-on tool though...
That's correct, and you can verify that by watching the valves that you want to adjust. When 1, 2, 3 etc are slack you're at TDC for cylinder one, then rotate one revolution on the crank and you will see the TDC mark on the flywheel with the rotor pointing away from the diagram you posted. Then you can get valves 4, 6, etc. I try to get things close and then run for a while to heat things back up - you can also use that opportunity to stick a piece of vacuum tube in your ear as a stethoscope and find which ones are still clattering so you can concentrate on checking them more thoroughly with the feeler gauge.
Yeah, adjusting while actually running is for masochists who hate their tools. Check while running (or listen to focus your efforts) and then make adjustments when stopped.
^^ditto on the fan belt. stand on the leaf springs, put on some gloves and pull in opposite directions on the belt. you can easily see the flywheel when you do it. but first! take off the inspection cover and clean and paint the BB and the line with a paint pen. makes all the difference.
nice
is the inspector cover just the part that has the window on it, or is it accessed from below the truck?
under the truck, protects from the flywheel from the outside environment.
No luck with the pull bolt, no way in hell I'm getting to that with the custom bumper and winch.
Tried cranking the alternator, no luck, just spins, I did tighten it up a bit and put pressure on the belt. No luck, not even close.
Ended up just manually rotating the fab (it's a 4 blade metal fan). Sounds the engine no problem at all.
Everything was pretty damn close, which is good to know That in a bind I can do it quickly with the engine running.
Had plenty of tweaks. It seems to be running better. Tomorrow morning when it's cold will be the test.
Thanks again for all the help.
Started up like a dream this morning. Drove it over 100 miles down to my Monterey Bay. No complaints, the
Running great. Thanks again for all the help.
