First time Birffer...
New Mexico/Colorado
Completed front axle service...a few key observations :)
Taking it all apart is reallly quick and easy
Cleaning it all up sucks...lots of paper towels and Brake Cleaner
Trunion Bearing races can be put in upside down...:(
Brass Drifts bend if you hit em' hard enough trying to remove bearing races...also be sure to hit the drift, not your thumb:mad:
CruiserDan gave me all the right parts the first time around...can't beat his service
Did i mention that getting those races out was a B!#$(
Next time won't be half as bad :beer:
Bir job is always messy!!! you can actually use the 3/8 extension to get the race out, much easier.
x2 on getting the races out. It's no fun when your doing it in the parking lot of your apartment complex and you know you're pissing off your neighbors with all that banging!
Don't quite think i made myself clear...the races when put in backwards give you ANYTHING to whack at...When the taper of the Race is upside down, there is NOTHING to hit against except the actual surface of the race the bearing runs against... again, it was a real PITA to remove :bang:
I feel your pain! It's definitely hard enough when they are put in the correct way!
