First the HG, now this...
Ipswich, MA, North Dakota, Phoenix
Just had the HG replaced by the local dealership. Truck ran fine before, but there were signs of trouble, so I thought I'd better bite the bullet and just get it fixed:grinpimp: ... Now, when driving 60 mph or so, every few minutes, it has a slight hesitation.:mad: The mechanic rode with me, with his plug-in circuit tester, and it didn't show any obvious electrical problems on the read-out, no missing, etc. The tester plugged in above the fuses. I left the truck with them, and they just called and said the code indiacted that some other $200 part needed replacing. The truck is a '95, has 178,000 miles on it, and until now, ran perfectly, in fact, I hesitated doing anything to it fearing just this sort of problem. It does need O2 sensors, which I'll install when I can find them (just moved), but don't think they'd cause this. Anyone have any ideas? I'm beginning to get tired of this! Thanks, Ned :confused:
Do you remember what the $200 part was?
I have an idea: tell us what the part was. Then we won't be flying completely blind.
In the meantime, I'm going to guess that it could be the part, whatever it is, that they said needed replacement.
Fuel pressure regulator?:confused:
Sorry guys:o In a rush at work. Throttle position sensor. I think the code was 210. Looked in my handy dandy Haynes manual, and I'll try to mess around with it this weekend. Does it make sense that it might make the engine hesitate?
Yes, a tps would definitely cause an intermittent hesitation. The FSM has detailed info on testing and adjusting it, thats what I would try first. Before I did that though, I'd check and make sure they didn't adjust the throttle cable incorrectly, or could be just a loose connection at the sensor itself. HTHs, James.
If they did the HG work the traditional (vs the HG video way - shameless plug) way, they disconnected your entire engine wiring harness to get the intake manifold off. If so, they were disturbing a lot of connections, grounds, and wiring looms and it could well be there's simply dirt in a connectors somewhere, etc. You should let THEM figure it out by having THEM pay an automotive electrician to diagnose what's wrong. Believe me, that's not going to be cheap - several hundred bucks to recheck your engine bay connections.
DougM
i second what doug said, while they are in there be sire to put dielectric grease in there
