first landcruiser
I just bought a landcruiser, 1987 with a V6. The body has a few small rust spots and the interior is great. It cruised along on the interstate at 70 with no problems. The only issue I have is the manual throttle, I have never even seen one of these. But, I only paid 2000 and think that is quite a steal. I was wondering, however if there are any common problems with this year and make that I should watch out for
Thank You
Its a straight 6 not a V 6. Manual throttle is aftermarket or non usa add on. Do you mean manual choke? Never use the manual throttle for a po boy cruise control. Rust is an inherent weakness, also rear main seal leak also front hub leak. Leaf spring sag is common. That's why most lift them. Take detailed digital pics of all smog equipment routing, etc (vac lines hoses etc) for later in case something comes off. It all needs to function together to function properly. If it runs pretty good, get the brakes tuned and tight first. 87 is a good year because a Toyota non usa 5 speed is bolt in for this year if you want to later. Carry spare parts behind the plastic panels in the rear of the truck; theres a ton of space there. Get an alternator(cheap, sometimes NAPA has rebuilds), cap and rotor, spare hoses and belts, maybe a starter. When these rigs break down with simple probs, it may be hard to get parts quickly if on the road; carry them and you'll have them..
60 series are tons of fun; can carry a small travelling circus in the back. Excellent climbers too due to long wheel base. Will last a long time if maintained. Get the rust fixed soon or it will eventually eat your truck. Enjoy the rig and don't take it too seriously.
