First area to Dynamat?
Fort Apache: Victoria
I just foundmyself recipient of three sheets of Dynamat. It's enough to do both front doors, or the front floorpans/centre hump.
My biggest ambient noise source is the tires. Where should I u my first Dynamats? If there's enough of an improvement, I'll do the whole interior at some point.
I would do the floor; when I did the doors it helped, but I feel that the road noise reflects off the road and enters the cabin through the floor more than the doors. I think the floor was more effective ;)
do what's easier. no matter where you put the dynamat, it will only make the noise seem louder from the area that isn't :)
I would do the doors- the backside of the sheetmetal, not the subframe.
Save them and just do the first place you need to go into for another reason...
I did my front doors when I replaced the speakers. Then I did the sheetmetal around the PS side tire when I pulled the trim and installed the amp back there.
Well, I did the front doors. I went with the doors because I neede to re-grease the regulators anyway...
So far, there doesn't seem to be much reduction in ambient noise, but the front speakers do sound much better. In fact, I have now turned down the gain on the rear subwoofer because there's so much more low-frequency in front.
I followed the directions and skinned the subframe. I barely had enough to do both doors, but I had a couple of square feet left, so I spread the left-overs around inside the door cavity, behind the speakers and a few other places behind the stock access holes.
I think if I continue with this project, I'll do the floors before I do the rear doors. I'm hoping to get new seats in the next month or so, and I'm planning on new carpeting once the seats are being swapped-in. That would be a good time to do the floors....
