Firing order, valve clearance help???
Hi guys,
I have the 2f rebuild manuel, but its different to the f specs! :slap:
Can anyone help me with these specs for an f motor :
1: firing order
2: Exhaust valve clearance
3: Inlet valve clearance
4: Feeler gauge settings
Metric or imperial would be great!!
If anyone can help in would be great!! :cheers:
1-5-3-6-2-4 too young, too old, just right ;) firing order
Exh .014"
Intake .008"
Set valve lash with the engine warn and rockers stand fasteners tourqed.
Good luck!
-Steve
Cheers mate,
That helps heaps, the rebuilt F was started last night and has awsome oil pressure, its just running a little rough without the info you gave me. Hopefully now it will be smooth as, :cheers:
[quote author=Poser link=board=1;threadid=13248;start=msg122284#msg122284 date=1079476722]
Exh .014"
Intake .008"
Good luck!
-Steve
[/quote]
Perhaps in the fullness of time and experience you will come to find that 36 isn't too old. ;)
Rode hard and put away wet. Eh, Steve? Just you wait.
Those numbers are the same for F and 2F, I do believe!
Yes those numbers are for a F or 2F engine...
No, not really "Rode hard and put away wet", just play the game of life a bit more intense than some... :)
Good luck!
-Steve
A little different. According to the '64 manual, valve lash for the F135 is .010 intake and .014 exhaust. So the minimum is just a hair wider for the intake valves.
