- Vehicle Model
- 200 Series
- LX570
- Location
- Chicago, Illinois 60523 United States
$1435 brand new in box, selling $400 + shipping firm
www.cspracing.com
ICON Vehicle Specific (V.S.) 2.5 Aluminum Series shocks are designed and built to give your vehicle outstanding performance off-road and a smooth ride on the street. These shocks are configured specifically for each application in both length and damping tune. Like all ICON'S Shock Absorbers, V.S. 2.5 Aluminum Series shocks are 100% rebuildable and 100% revalveable. For piggyback and specific remote reservoir applications, ICON'S unique use of a 6061 billet aluminum manifold a few inches below the top cap of the shock creates an internal Bump Zone that when used creates an additional 20% of damping force. This additional force helps prevent harsh bottom outs and controls the suspension when compressing at high velocity. The ICON CDC Valve is an externally adjustable valve that restricts oil flow into the reservoir which creates 10 levels of compression damping force ranges. If you are looking for a more user defined tune, consider looking into the Omega Series bypass shocks.
AAP_UDA_22: 1
AAP_UDA_4: 55
Add-On Part: 252012 - -4 TO -10 HOSE SHIELD KIT
Add-On Part: 252008 - 2.5 X 13 SHOCK BOOT BLACK (PAIR)
Adjustable: Yes
Boot Included: NO
Bore Diameter: 2.25
Cylinder Color: Silver
Cylinder Material: Aluminum
Damping Type: Oil
External Reservoir: Yes
Gas Charged: Yes
Grade Type: Performance
Lower Mount Type: EYELET
Mounting Hardware Included: Yes
Service Parts: 611007 - 9/16 MEDIUM DUTY STEM BUSHING KIT
Service Parts: 191016 - 7.5" FINNED RESI UPGRADE KIT
Service Parts: 254100G - 1 GALLON ICON PERFORMANCE SHOCK OIL
Service Parts: 252002 - UNIVERSAL SPANNER WRENCH (2.0/2.5/3.0)
Service Parts: 252001 - 2.5 FIXED SPANNER WRENCH
Service Parts: 252003 - SEAL INSTALL TOOL 2.5/3.0
Service Parts: 252011 - 2.5 PIGGYBACK/REMOTE RESI/BYPASS REBUILD KIT
Service Parts: 257339 - 7/8 SHAFT 13.25 OAL, 9.00 TRAVEL
Shaft Diameter: 0.875
Shaft Material: Chrome
Shock Absorber Body End Measuring Point: Shoulder of Stem
Shock Absorber Rod End Measuring Point: Center of Eylet
Tube Outside Diameter: 2.5
Upper Mount Type: Stem
Icon 57825CP - 2008+ Toyota Land Cruiser 200 0-2in Rear 2.5 Series Sho
Icon 57825CP - 2008+ Toyota Land Cruiser 200 0-2in Rear 2.5 Series Shocks VS RR CDCV - Pair08-UP LC 200 0-2" REAR 2.5 VS RR CDCV PAIR2008-UP LAND CRUISER 200 SERIES 0-2" LIFT REAR 2.5 VS REMOTE RESERVOIR CDCV SHOCK PAIRICON Vehicle Specific (V.S.) 2.5 Aluminum Series shocks are designed and...
www.cspracing.com
- Remote reservoir design improves heat dissipation to reduce shock fade during prolonged use
- 6061 aircraft grade aluminum CNC machined components
- ICON’s internal “Bump Zone” increases damping by 20% to provide more control as the shock approaches full compression
- PTFE lined spherical bearings and application specific mounting hardw
- ICON's CDC Valve technology allows for 10 levels of high-resolution compression adjustability with the turn of a knob
- 7/8” diameter induction hardened, chrome plated shock shaft
- One piece digressive piston design with vehicle specific valving for unsurpassed performance and ride quality on and off-road
- Nitrogen charged monotube design with piggyback reservoir
- Premium grade 5WT shock oil for consistent suspension damping along a wide temperature range
- One-piece impact extruded aluminum cylinders offer excellent corrosion resistance and consistent finish
- 100% Rebuildable
- 100% Revalveable
AAP_UDA_22: 1
AAP_UDA_4: 55
Adjustable: Yes
Boot Included: NO
Bore Diameter: 2.25
Damping Type: Oil
Gas Charged: Yes
