Fire hazard?
NJ SUCKS
Website
www.recordme.com
it’s looking like I have a bad possibly leaking and injector(Runs real rough blowing smoke strong gas smell Looks like something burning up on the manifold when it runs.) is there a chance my truck will burst into flames if I drive it to the shop should I have it towed? Just posted pictures of my spark plugs on my last thread if anybody wants to peek.
thanks as always guys
You may have a damaged wiring harness around either the EGR pipe or the glove box.
If the injector is running constantly it will dump gas into the cylinder, which can leak out of the manifold/pipe junction and cause the truck to miss badly and the exhaust to smell like fuel big-time. One common reason for this is the harness shorting out where it rubs against a metal bracket just to the right lower corner of the glove box. If you find this to be the issue, fix the harness and change your oil- the gas will run past your cylinder rings. Your oil dipstick will smell like fuel as well. I'd recommend not driving it for several reasons- fire, no oil in the cylinder rings, and diluted oil. Whatever the problem is, figure it out before running the engine.
Credit to @Tools R Us for diagnosing this issue over the phone for a truck out in the boonies on a trail run. We would never have found the issue and would have had to tow it home, with his help we were up and running in a half hour.
Great info I kindly appreciate you taking the time to help me out
