FIPG Q?
Ashland, OR
I just finished replacing the AT oil pan. The FIPG instructions state that the engine can be started in two hours. It is cured in 12-15 hours. How long till I can safely drive the truck. I need to go scout a river tonight @ 5 hours after the install.
Thanks.
Thanks.
Just talked to the local Toyota Dealer service department. They said you should let it cure before driving or it won't harden up and seal. It'll just stay mushy and leak.
Sorry, I know that's not what you wanted to hear but....
:cool:
At the shop where I work, we usually fill the tranny then start the engine within minutes of replacing the pan...
Probably not very good practice, but we've never had anyone come back because of a leaky pan.
X2. Never had any leaks either.
I'll go fish tomarrow. The road into this spot is quite rough so I'll let it dry over night just for the heck of it. I just need to remember to replace the fluid.:hillbilly:
Thanks for the input.
better safe than sorry.
although I doubt it would cause any problems I would wait just for peace of mind, and not having to do the job a second time.
You did wrenching on your truck without calling 5 people over to "help" (do the actual work) while you ran to NAPA and watched the kids? :lol:
Actually I had the twins do the :wrench: while I drank beer.:beer::hillbilly: Only problem is I am still trying to figure out where all the extra parts came from!:doh: (kinda like workin with you!:flipoff2:)
I'll add another data point here, and a slightly embarrassing one at that. :o When I replaced my tranny pan I, in typical turbocruiser fashion completely prepped this project out ... I had ordered a brand new pan and all brand new bolts from cruiserdan, I then carefully removed the old pan, chased the threads of the tranny, cut the heads off of several of my old bolts to use to "locate" the pan the first time without wiggling the pan around, completely cleaned the new pan, completely cleaned the tranny, carefully spread the FIPG onto the pan and carefully lined up the pan and the tranny with my home made locator studs, and finally got ready to position the pan. :cool:
It was supposed to be like a space station docking procedure, and it was I tell ya, right up until that one split second when I saw a small drop of ATF hit right smack in the middle of the FIPG on one edge of the pan!!! How the hell it did that I have no idea because I basically let the tranny drain the entire time I was dicking around cleaning the new pan and cutting the locator studs and cleaning the tranny, etc. Long story short (well that already was long huh) for whatever reason (prolly the three rum-and-cokes I had during the damn long prepping procedure :D) I did something I never do after so much planning ... I thought to myself "WTF" and left it as it was!!! :eek:
Sure as snot that one little itsy bitsy area right there, and only there, sweats out fluid and frustrates the hell out of me to this day! :mad: Moral of the story: FIPG needs to totally cure without contact with ATF; if there is contact with ATF the FIPG seems to stay in a state of mush and cannot hold hot ATF back. I recommend replacing the pan with proper FIPG, letting it cure overnight, then refilling the tranny in the morning. That should assure no leaking whatsoever. If you cannot do that at least avoid getting any ATF on the FIPG like I did :doh: and wait as long as you can prior to filling and driving. I really think that even an hour or two while working on something else would give the ATF a better chance then just fast filling and going. HTH. :cheers:
Since we are being honest....
I saw some drops the FIRST time I installed the pan. I also felt a "bump" as I lined things up. After getting it all together I thought to my self " did that little bump get FIPG on a critical tranny part?" I pulled the new pan, no FIPG on the internals!:censor: Clean all the tacky FIPG off, redo the whole thing. Note to self don't bump things when installing pan.
I waited till this am to refill with ATF fluid. I should be good to go.
Thanks!
