Final heat riser leak question
Yucaipa, Ca
I’ve read most, if not all the links on this topic, but... I REALLY don’t want to disassemble the entire manifold to repair the bushings (or lack thereof) to stop the pesky heat riser leak. Please tell me if this makes sense and keep in mind that I live in Kalifornia and subject to smog tests. Oh yeah, it’s a ‘76 FJ40. I’m thinking that without removing anything, I can rotate the riser spring CCW 360 degrees (into the hot position), and then braze each exposed end of the heat riser rod to the manifold thus locking it into place and sealing the exhaust leak. Is this doable?
I’ve read most, if not all the links on this topic, but... I REALLY don’t want to disassemble the entire manifold to repair the bushings (or lack thereof) to stop the pesky heat riser leak. Photos?
Please tell me if this makes sense and keep in mind that I live in Kalifornia and subject to smog tests. u get only 1 shot
to get this particular repair u are describing spot on , if u can do it on the car so to speak the make it so ,
But ........................
It is way easir & u will achive better results , if the exhaust manifold is disassembled , plus your working flat not vertical
also, how u plan to keep the Braze-alloy in heated liquid form from running down till it cools and cures solid ?
are u sure CCW is in the HOT engine position ? U need to Triple Verify this mission critical
step , i have seen 2F manifolds that rotate in the CW position when a HOT engine , i dont know the WHY behind that , or a
production date change for example to distinguish the 2
Is this doable? i don't think so , and i laid out the WHY's above , in addition what concerns you about the Smog Kalifornia topic ? u are going to Braze it either way right ?
are u 100% sure the 2 shaft side bushings are your problem and Not a cracked manifold or a Leaking Heat Riser Gasket ?
i have Never seen those 2 bushings LeAk enough to cause a exhaust leak that warrented a repair ?
thats not to say its impossible , and maybe i have simply Just not seen one yet type thing
I personally use a MIG welder , on its highest setting , combined with Pre-Heating the manifold with a MAP gas torch
i only spot weld the shaft in 2 locations like
9 oclock and 3 oclock , since i am only doing this to immobilize the shaft and
set the heat riser Flapper in the HOT engine position
if i take take the manifold off , i cut the shaft out and install 2 stubby metric hex bolts and fully MIG weld them in place to
seal and potential future leaks
i hope this helps
i hope this helps
Thanks, I can actually can feel the exhaust spitting out of rear of the manifold at the heat riser rod. You can only hear it while under load, not under high rpm without load. I disassembled the manifold and fortunately no cracks. The gasket mating the exhaust and intake showed no imperfections or evidence of carbon to indicate it was leaking. I removed the heat riser and fabricated two spacers that matched the interior width of the two holes on each side of the manifold. I then found two washers that snugly fit the indents on the outside of the holes where the heat riser rods exited the manifold. I put a liberal amount if copper gasket sealant on the washers, backed them up with a slightly larger washer, another washer on the inside of the manifold and bolted (grade 8) them tightly together along with locktite. I will now install the SOR exhaust plate and put it back together. I’ll keep my fingers crossed.
