Filling the void
Broken Arrow, Oklahoma
With Buckroseau taking a few days off, I know everyone on the 45 board is wanting to see a LWB be worked on. So I thought I would post up a few pics of todays work on mine....
Dont you just hate it when the PO (or the factory) leaves unsightly holes in the dash and firewall? I decided to weld some up.
I closed up the ashtray and the gauge cluster area, also filled in the ignition hole (I am moving it to the other side of the column), and a few others.
I won't be needing the heater holes in the firewall, and also wanted to close up the hole for the column, since an aftermarket column will require a new hole anyway.
I am NOT an experienced welder. A buddy of mine showed me how to weld when I was working on my frame (boxed it and made a few other changes); that was my first time ever. Same buddy gave me a lesson on the more refined art of sheetmetal as opposed to frame steel the other day. I think it came out pretty good.
tips
The only tips I have to share are what my buddy told me.
Make the patch peice fit as closely as possible so you dont have a big gap to fill.
Do spot welds, let it cool, then more spot welds and cool.... repeat the process until it is all done (just a series of spot welds that all connect eventually).
When grinding the welds down, again, try to never put too much heat into it that might cause warping.
So it is a slow, time consuming process.
Also, dont forget to take the zinc coating off hte new metal with some muratic acid....
