fibre glassdoors
I'm putting some on in the next few weeks. Mine came off my '84 40 and are going on my '84 Troopy so everything should be straight forward as its pretty much a bolt on operation apart from some cosmetic issues with door linings etc.
I imagine that ppl's experiences will differ from brand to brand. Just a matter of jumping in and keep going untill you are happy!
Lup:)
Thanks for the reply. what i was really wondering is how the door hardware is bolted on. I assume there is no captive bolts or threaded holes as there is on the steel doors. Did you fit the hardware on to your fibre glass doors? O yes, what are PPL's?
thanks james
428 liley, your question got me motivated enough to start striping down my old f/g doors to have a look what I need to do get them ready so thanks! I pulled off the inner lining which is off an original door, (all hardware features on my doors are factory BTW), and had a good poke around inside. Most external things are bolted through the outer skin, like for instance the mirrors and sucured with a nut on the inside. I presume you will have to drill these holes yourself like I did when I put my f/g half doors on the 40. You might have slight moulding marks where factory holes are? I think they leave these on purpose to make it easy for you to place things but again different manufacturers probably do things differently. I found a makers stamp on the inside too - a company called Hurrican Fibreglass that is or was local to me so not much use to you! They did a 45 ute roof for me many years ago but I'm not sure if they are still doing panels.
My doors look as though they are really well made and are indistinguishable from the real thing. Ok, so cruiserheads/cruisergeeks would be able to tell the difference with a second look and a tap here and there! The inner skin is where all the action is. Where the factory hardware does not have a backing plate with threaded bolt holes (like the winder mechanism has), the manufacturer has used a sort of nylon bush that is pushed through and clips to the other side of a drilled hole and short self tapping bolts are screwed into these bushes to secure the hardware to the door.
An interesting feature is how the hinge is fastened to the door. Where the three hinge bolts go an extra layer of f/g has been added and into this extra layer are molded three funny threaded things so you cab screw your hinge bolt straight in. The threaded things are kind of a female threaded sleeve with a flange that sits parallel to the outer door skin. On the flange are four spikes that face back inward and help to secure the thing into the f/g when it is moulded. Clever little buggers! My half doors where different in that they had a steel plate moulded into the hinge recess area. Didn't know it was there until I started drilling my hinge bolt holes! I just bolted my half doors on with large washers on the inside but with the extra weight of a full door I would definately try tapping a thread if your doors come with a steel plate inside the hinge area. Check with your manufacturer how best to hang your doors.
Also pay extra attention to how your swing limiters(?) are secured to the door. I have some stress cracks around the bolt holes where mine have been swung open over and over. Put as large a washer as you can or even better a backing plate on this area to spread the stress load of when the limiter hits the limit!
HTH but alot will depend on exactly how yours are made. Get all the info you can from your manufacturer on how they are made and what they recommend when fitting. I gotta get my star sorted. Pics would have helped.
Lup:)
Thanks Lupdog. it looks like I would have to spend about 1200 euro to buy a pair of doors so I may have to consider replacing the lower part of the existing door. Can you tell me who supplied your fibreglass and roughly how much they cost?
Thanks
James
OK. My full doors came with my 40 when I bought it so I don't know how much they were. Here is a link to a local site here in Queensland. No prices listed, but you will get a feel for what can be done and some basic info about the product. Have a look through the site, there is some cool stuff:
http://www.ozeastfibreglass4wd.com.au/index.html
If your talking euro's then I presume you are in Europe? Buying from the states would have to be a better option than Australia but shipping costs will still eat into any savings. Try doing a search here on mud, (at the top of the page!). Look for fibreglass, body panels, etc. You will find the information you are after such as who makes them in the US and you will learn a hell of alot along the way.
Search function - sometimes the journey is worth more than the answer.
Good luck
Lup:)
