FHH question
Oregon
Website
www.brian894x4.com
I checked the FAQ and searched, but nothing found. Most threads deal with the PHH or the heater hoses to the rear heater.
My question is cocerning the Firewall and other non-PHH heater hoses. I noticed the common silcone kit that everyone gets for the PHH, includes another kit for two firewall heater hoses right over the valve cover. Obviously this must be a common failure point.
I'm curious why only these two hose? I see a bazillion other heater hoses including a bunch down by the firewall and exhaust that look like they could pose a problem too. Are these two heater hoses under higher pressure or something?
I don't have any failures and everything appears good, mileage is just under 100K, but I'm going to do the PHH and these two FHH just as preventative maintainence. Are there any others that are also prone to failure that I should do at the same time?
I believe the PHH is exposed to more intense heat than the others and that is the reason it fails more frequently.
With that said, after 13 years you can never change too many hoses.
Mine started to seep around 150k same with rear heater hoses. Rear heater hoses where easy the fire wall hose was a harder (used silicon there). Very easy while the head is off.
Brian
I just finished all my heater hoses, including PHH. What a pain in the ass... but I feel much better knowing that I have all new hoses. I did forget to do the rear heater hoses and will be doing them in the near future. As far as hoses go, I was able to find some silicone hose at a semi-truck supplier in town. The semis use the silicone hoses quite a bit, so if you have one of the suppliers in town for big rigs they will probably have silicone hoses.
I also ordered the Breeze constant tension clamps from parts systems in Portland Or. If you use silicone hose you should use constant tension clamps so you don't get leaks when the hoses are cold. I also got the bigger ones for the radiator hoses. Cost me about $100 just for the clamps. I was able to get the silicone hose for $4.50 a ft. If you don't have a big rig supplier you might try www.sporthoses.com . They sell a 3 ft one for about $40.00. That will be more than enough to do the PHH, the heater hoses next to the firewall, and any other straight hose.
A couple tips for the PHH, go down to Napa Auto Parts and get some Sil-Glyde, this is a silicone based lubricant, and spread it ALL over the inside of the PHH and slip it onto the tube. Then line up the tube and block nipple and slide it on.
:cheers:
Thanks much for the info, but one of my questions still stands...
...what makes the two firewall heater hoses that are part of the silicone kit on this site so special?
index
I assuming these two hoses must be prone to leaking more than all of the other heater hoses, except for the PHH...if so, why is this? There are other heater hoses that are closer to the exhaust, so I'm guessing maybe they are higher pressure or something like that?
Does anyone have a diagram showing all of the heater hoses, their locations and what the part numbers are?
That would sure be nice....too easy...but very handy.
Be super careful when removing the hose that goes into the firewall.
I found out the hard way that the pipe comes quite far out and I managed to really buggering it up with a pair of pliers due to impatience.
Lucky for me CDan talked me down and I was able to RnR it so that it doesn't leak. Otherwise I would be going into the dash to the point of removing the heater core.
All this because I didn't want to cut the hose off so I didn't score the pipe. :lol:
I do have that $25 pipe in the parts bin ready for that time and proud to say the only one that Dan has sold. :lol:
Brian
As far as I can tell there is nothing special about those two hoses. It is just another kit that the vendor put together. I agree that even regular Toyota replacement hoses will work for all the coolant hoses, even the PHH. Remember the hoses that are on it currently lasted 12 to 14 years and many....many... miles.
To increase the time between changing you can use the Gates green stripe or Silicone hose. The burst rates are higher on these then regular hose.
You can get the same hoses and clamps from the two sites I posted earlier for almost the same price as the 3 hoses. The 3' foot hose will give you more silicone hose to do other straight coolant hoses on your rig.
If you have a FSM it gives you the aproximate locations of all the heater hoses. Give yourself a full weekend to complete the job. At least that is how long it took me... ....
:cheers:
Cool, thanks for the info.
I was thinking I would drain the coolant and do this, while I'm adding the 150amp Toyota alternator. Just gotta collect parts and find a good weekend.
I'm not sure if I'll do all the hoses, but if there are others that are particularly vunerable, I'd like to get those for sure.
