FHG Failure
Hey everyone,
Just thought I would post up. I sold my locked 93 in November and bought a 98 4runner. Somehow the 4runner truck just didn't feel right and didn't feel like an 80 series (read: withdrawl). So I sent out on a quest to find another 80 this time 95+ and ended up buying a 96 lx450 about two months ago. Well it drove great for about 1500 miles and then, the HG went in a spectacular fashion. Well I was going to have Robbie take care of it but my brother took it off my hands. The head work is being done from "Heads by Drew" who has done excellent work in the past for other projects for us.
I want to get the gas tank and the lines cleaned. Does anyone know who does that in the denver metro area?
Enjoy the pictures; my .02 HG should be done as a PM for trucks over 150k+.
Q
he means just replacing the gasket set..ect and doing it yourself- machine shop is gonna run you around 650-675 for the head work, then if you pay someone to do it look for over 2 g's... mine complete with head work is gonna run me around 3 grand. which is pretty much the going rate if you have someone do it-
Generally, you won't need machine work - just clean the head and block mating surfaces, slap a new gasket down and bolt it back together. You can rent a block flatness checker.
As for the fuel tank/lines I don't think that's worth doing. In 10 minutes you can be looking down into your fuel tank via an access hatch from the cargo floor. You could replace the prefilter sock at that time and if you see dirt merely drain it with the drain on the tank's bottom and clean. I don't think you'll see dirt. With the prefilter your lines will also be clean.
DougM
Yes, this is what I meant. Landtank did his (he was, from what we know, one of the first to do it as PM) for a very reasonable price.
Most heads do not need machine work--you can easily get through this without going to the machine shop if your head is in good shape and was not injured by a blown HG (i.e., you caught it in time or did it as PM).
-o-
Just did mine about 2 months ago for right at 550, including the machine work. They decked it, valve job and adjustment. Runs prretty damn good. No CEL, leaks, or left over bolts. Sorry to hear about it.
:beer:
