Guys,
I'm changing my power steering from mini truck to Saginaw and it's not cheap. I'm over budget with more needed to finish. Hopefully someone needs this stuff:
Mini PS System: $275
PS Gear Box with 40 pitman arm and pedestal to attach to frame where OEM manual box is
PS Pump with remote reservoir and fabbed bracket to mount in smog pump location
PS High Pressure Hose - outer cover has a couple cracks, but it holds fluid fine
All you need to complete this is a few nuts and bolts, return line, hose clamps and a belt.
75-83 front door window regulators - $40 for the pair
75-83 front door glass - $50 for the pair
Steering center arm assembly - pivot mounted in front of front cross-member - transfers steering forces from the relay rod to the drag link Rebuilt ~6000 miles ago and never adjusted since, so it should have plenty of life left $60 rebuild kit is $48!
If anyone has them, I need an HD drag link (saginaw pitman arm to right knuckle) with left hand metric thread on one end and right handed SAE thread on the pitman end. I can even have a 40 or 60/62 series tie rod cut and threaded for the SAE TRE if that's all I can find. Also need a pitman arm with 2 to 3" drop and at least 6.5" long.
Thanks for looking.
Lash
Thanks for looking.
Lash
