Few engine issues trying to resolve
Boonsboro, Maryland
Almost got this thing back from the grave. Trying to sort out the last issues I am having.
First is the carburator. it is leaking gas out of the shaft of the butterfly valve in the primary. Towards the front of the engine. little clip with the nub of the shaft sticking out. Now when I noticed this I had just turned the engine off and was going to fire it up again. I am thinking it only does this when gas is sitting on the butterfly valve and also only when the engine is shut off.
Related. the engine is dieseling for maybe 5 seconds after the ignition is cut off.
I am thinking that that dieseling is keeping gas up top and not burning it.
Timing is set to spec. maybe retard it a hair?? Still dont think gas should be able to come out there though. Carb is rebuilt, Did not touch the valves.
2. Put a GM 3 wire alternator in. It seems to be charging fine. but the idiot light I hooked up per wrie ups is not turning off when engine is running.
Simple wiring. batt- battery. #2 wire is going to fuse box. #1 wire to idiot light.
Anything wrong there. Using 1 side of an 1157 bulb.
if I can get these things figured out. I think I am on the home stretch and can get this thing on the road before the summer is gone. Thanks. Mike
its a 9/71 engine and stock 2 barrell. I am going to get a vac gauge tonight and make sure all is good and adjusted and check the timing again. Go from there.
but dont like gas on the manifold for obvious reasons.
Solved most of my problems it seems.
The gas leaking is only happening if you give it gas too much prior to start and when it was dieseling it was just dumping it onto the valve and it had no where to go but out the shaft.
The dieseling was a stuck idle cutoff solenoid. it WAS working. cleaned it and flipped it upside down and it seems good to go. Cuts right off. Gas is contained.
Vacuum is good at 18hg. It is stumbuling a little when you tap the gas???? but that is it.
Still can not figure out what is up with the alternator. Dosent seem to be charging either. The light will not go out.
battery cable to battery. #2 termial is to the fuse box, and #1 is grounding an idiot light fed from the gauge circuit. ??????? Alternator is new. ??????
There is no gas leak. It is normal for fuel to run out the end of the trottle shaft. There is no seal on the shaft, and the fuel is introduced into the airstream above the throttle. Some of the fuel condenses out on the throttle blade, then wicks out the end of the shaft. This is most visible when the engine is shut off. When the engine is running down the road, there is no fuel coming out the shaft because the entire carb below the booster is seeing vacuum, so air is being sucked in around the shaft, rather than fuel creeping out the shaft.
The dieseling is happening because the alternator is/was backfeeding into the ignition circuit. The ignition circuit supplies voltage to the alternator regulator, ignition coil and the idle solenoid. It wasn't actually dieseling (running on due to a glowing hotspot inside the chamber) but was idling w/ a very weak spark and a stuttering idle solenoid. Common problem w/ GM alternator swaps. Search the web for proper installation of the alternator and inline diode to prevent the problem.
For now you can reinstall the solenoid right side up (wires coming out toward the valve cover) and disconnect the alternator wire #2. It will run & shutoff fine. Still won't charge, but that will get taken care of w/ the right wiring.
Got ya, not sure which though. The gas is definetly as you said. No more problems there.
I tested the cutoff and it wasnt working kept getting stuck. Once I bench tested to where it was working all the time and put it back in the engine cuts right off. I have yet to change anything with the alternator.
I wired this cruiser from scratch as well so no existing factory wires are there. alternator fuse is seperate from ignition and idle solenoid.
Thanks for the info. It is almost there.
The alternator, ignition and idle may be separate fuses, but they all come off the same switched pole on the ignition switch. Power can backfeed, from alternator terminal, through charge fuse to ign switch post, back down to ignition fuse and on to coil.
