Fender removal question
Dacula, GA
I just picked up a 94 fj80 this past weekend and the fenders are already removed, but I wanted to durabak where the fenders were. For those of you that have does this before, what did yall use to fill in the holes that are there from the clips that held on the fenders?
Nick
Nick
Bondo, weld them, alumuminum tape, or any other sort of filler/cover.
On cdan's :princess: rig, she has (elephant IIRC) stickers covering all the holes. :grinpimp:
All depends on how good you want it to look or if you are trying to get it water tight. aluminum tape is the fastest way but if you are using a rattle can for your liner it will need to be a thick coat or the tape will show through a little. welding requires grinding, but will be the strongest, bondo is another bet but needs to dry and to be done corectly. Hope it helps. good luck!:cheers:
honestly, i taped over the holes after sanding, and just laid it so thick you cant tell at all where the holes are, so if you dont feel like taking forever... go that rt...
I was planning on bondoing the holes, but I have never do that before so I was seeing if there was anything else to do it with. The truck is definately not a show truck, I only paid $1400 for it and has quite a few cosmetic issues.
That sums it up. It all depends on how much time you want to put into it. I'm sure you will be happy with any of those options.
I had good results with jb stick weld this time round. I aluminum taped them last time that worked but I wanted something a bit more rigid this time. turned out nice and the stuff sets up fairly quick
HTH
Aluminum HVAC Tape .... Very smooth, and thin, and holds up ... After two coats you will not be able to tell ....
Good luck!!!!
-Josh
Well, yesterday my girlfriend and I herculined the truck. We ended up putting HVAC tape over just the hole and then put some bondo over the tape. We also herculined the hood, because when I bought it, the hood was very faded.
Looks good! Question, Why did you line the inside panel? Any plans to lift or mod in anyway? :cheers:
Yea I am planning on lifting it and putting some protection around it so i can start wheeling it. I just bought it 2 weeks ago and it didnt have any fender flares on it so I wanted to go ahead and put this stuff on first.
