- Thread starter
- #21
Damn, that is a good Slee copy![]()
Sorry ... they say imitation is the best form of flattery.
cool , pretty 105where is the rear bumper ? did u change R&P?
It is being fabricated, a new gear set is also going in: 4.88 PG's.
Moving up to 37" and 17" wheels.
Where did you get your gears? You will need some additional parts to intall them. PM for details.
I got the from Slee Offroad about 4 years ago.
I am swapping an ARB locked 3rd member from my old 80 series so I can't see what I would be needing.
The differentials are compatible between 105's and 80's.
Thanks anyways.
All the 105's that we have provided parts for have the same rear 3rd member as a UZJ100, which means 32 spline axles and a different ring gear pattern / carrier deck spacing. Since we dont have 105 here I am not 100% certain. If doing gear change and arb in a 100 diff you would need to comine components from an 80 series arb (rd33) and 100 series (rd64) + some machine work. Basically what you end up with is a RD33 with 32 spline axles. This will accomodate the 80 series aftermarket gears as well as you factory 32 spline rear axles.
