FATMAT removal ?
Somewhere
Hello,
I bought the LC80 last week and I am in process of cleaning the car. There was Fatmat installed by previous owner, unfortunately by the heat or other influences the fatmat glue is sticking out and it is a little messy. I tried to peel the fatmat off but it sticks pretty hard to the body of the car. Seems that it will be PITA to remove it. How would you suggest I proceed ?
Either leave it and clean the glue or peel it off somehow. Not sure what would be the better approach.
Not sure it will work with that stuff, but some have used crumples of dry ice in a small areas and then chipped it off.
Also wanted to ask what everything needs to be removed to take the carpet out for cleaning ? Do I have to take out the Front Console Box and Rear Console Box ?
You could just cover over the exposed glue with some plastic sheet or something similar. Probably a whole lot easier than trying to remove what is already there. That stuff is sticky
Thanks for advice, I will just cover that with some plastic.
Regards,
Jorge
just lay some aluminum foil over the black sticky stuff!
So I have the carpet out , what do you guys recommend to do with it . There is some old heat or sound barrier (looks like sheep hair) on the back of the carpet. Shall I remove it or leave it? I read that the best is to go to locale car wash and give the carpet some love with water.
I'm confused as to why you'd remove carpet to clean it?
Either leave it in and clean it, or replace it... No need to remove it if you're just cleaning it. IMO
That's what I read here in MUD a lot of people actually do that when they buy the car so I thought why not. Also good idea to clean it and check the wires under the carpet too.
Well if you can see the pictures I posted the FATMAT started to melt in high temperature. The car is from Arizona and AFAIK Fatmat is asphalt based product. The black mess what you see is the Fatmat melted. Also see here - there are some health related concerns with Asphalt based products, not sure how accurate it is.
First, Asphalt products are significantly poorer performers than butyl products (Raamat, SecondskinAudio, newer Dynamat.) This is both in damping and adhesion performance.
Second, and most importantly:
Quote:
Originally Posted by afscme
Health Hazards:
* Acute (short-term) Health Effects: Skin or eye contact may cause inflammation and skin rashes, changes in skin coloration, and an acne-like condition at hair follicles and skin pores.
Asphalt fumes are created when asphalt is heated. Fumes contain very small, solid, airborne particles which are easily inhaled by the worker. Inhalation of asphalt fumes can cause irritation to the nose, throat, and lungs. Fumes may also contain hydrogen sulfide vapors, which are very toxic, as well as the vapors generated by the solvents used to "cut" the asphalt. (See below).
Exposure to sunlight or other ultraviolet light (such as welding) may make these skin conditions worse
Chronic (long term) Health Effects: Asphalt cement also causes rashes and other skin conditions, possibly including skin cancers. In addition, asphalt particles left on the hands may accidentally get into the eyes causing severe irritation to the eyes. Hot asphalt may also cause severe burns if splashed onto exposed skin.
Do you really want to sit in an enclosed box surrounded by toxic-vapor leaking fumes to save a few cents per square foot?
Update from Fatmat:
Quote:
Hello Brian, this material is not dangerous and the information that is in that forum is talking about the asphalt that you would find on the road. What he neglects to say is that there are different kinds of asphalt which are made with different ingredients. Fatmat for instance has absolutely no hydrogen sulfide. The asphalt that is used in road construction does give off fumes because it is heated to the point of being in a liquid form which releases those vapors. As I am sure you know fumes and odor are completely different. The FatMat is mainly a rubber mastic with a asphalt mixture which is used for the adhesion. The only reason it has an odor at all is because it comes straight off the press and is sent to you.
During installation if you have sensitive skin it may cause skin irritation, so it is a good idea to wash up after the install, however that is not common
We have had this product tested and as long as it is not eaten but is used for its intended use it has no health effects.
(see below, brought this up to the top to make sure things are accurate.)
Read more: http://www.corvetteforum.com/forums...and-other-asphalt-products.html#ixzz3pELkPjKm
That't the factory jute backing. I'd leave it. But I doubt it will survive the car wash or being otherwise saturated with water.
Not a fan of the factory jute at all. If he has fatmat, I'm not sure he'll miss it either. Agreed that it won't survive a carwash.
