Fan troubles
Eureka Ks
I've installed a 5.3 into my fj40 frame I've mounted my original radiator everything looked great plenty of room to run my mechanical fan i was getting pretty excited i picked up some radiator hoses that where recommended here on mud thats when my trouble started if i install my lower radiator hose its gonna get karate chopped by my fan. sucky deal my factory GM fan is roughly 19inch if i had a 16inch id be golden easier said than done i did a internet search no luck called O'riellys no luck went to Napa no luck does anyone have another idea or know of a mechanical fan that works with my combo id really rather not run an electric fan thank you in advance for any help and for your time.:cheers:
My 2001 6.0 runs a stock fan that came on motor , 16" is real close, stock fj40 radiator, custom shroud, works well.
You can always trim your fan down.
Got any pics of the thermo housing and radiator so we can see if something is off ?
i have thought of trimming the fan worried that it would end up unbalanced might could raise my motor a bit not sure how much cause i dont have the body on yet here are some pics hope they show what u need thanks for the reply by the way
My heater hose outlets are approx. 4" above my frame rail. That may be the difference. If your motor is lower than that then you could just trim the fan. I would cut 1 blade down , use the piece as a template for the others being very careful to remove the same amount, make a jig or something, lightly sand the edges when done. But from your pic it looks almost identical. Not much clearance between fan and hose so I carry a small piece of tubing and hose clamps in case the chassis flex's enough to cause contact but I'v twisted it up a lot and never had an issue.
Thanks for the replies my heater hose nipple is 4 1/2 inches from the bottom to the frame seems if i would of raised my motor a couple inches id of been golden to late now everything is solid it didn't even cross my mind that i should of stuck in the radiator before i stuck it makes sense now LOL i raised and lowered the motor mounted up to the transmission trying to center my parking brake drum in the space above the skid plate so it wouldn't rub if i had for seen this problem i could of modified my skid plate pretty easy i read a thread on thebigredrockers page where another member talked about moving his bottom radiator spout to the bottom of the radiator with a 90 degree turn that would open it all up i called a shop today that said the would do it for $140.00 and clean and rod it out while they got it i think that's what i'm going to do THOUGHTS?
I don't think its all that big a deal. You motor is almost exactly where mine is, you could trim the fan or you could pull radiator, and make custom mounts that will drop the radiator down. I hate taking the fans off so you could trim it in the truck but that idea kinda sucks, couldn't be to bad with a dremmel tho. I really think lowering the radiator mounts is not that bad and solves the issue.
so this is what i ended up doing took awhile to get back to it but now its done and it solved 3 problems total.
Had this spacer made its 3/4" thick and will raise my motor 3/4"s fixed everything.
Now my fan spins freely my exhaust manifolds fit and my PTO drive shaft doesn't rub. Thanks for all the advise
